I'm at a loss for why I keep failing to publish a web map from ArcGIS Pro to ArcGIS Portal 10.8.1. I was able to get two maps published successfully, so I know it's not a permissions issue. Even when I pare down the map to a single layer with next to no attributes, I get the same basic error messages:
Status: Failed ErrorMessage: Failed to publish web layer
Status: Failed ErrorMessage: Failed to publish web layer Test_WFL1.
Status: Failed ErrorMessage: Failed to publish one or more web layers
I'm trying to copy the data since my Portal is not federated with Server.
None of the forums I've found so far have applied to my situation - I don't have a bad date field in any layer and I'm not trying to automate it with a script. Anyone else having this issue?
