Failed to publish hosted feature layer to ArcGIS Enterprise from ArcGIS Pro
2700
7
03-23-2022 04:29 AM
MohammedAlhessi4
Hello,
I have a problem of publishing hosted feature layer from ArcGIS Pro to our Portal on ArcGIS Enterprise.
The steps I used is shown in the following screen:
The error I got is here:
The error is:
"Server Response: ERROR: code:403, User does not have permissions to access 'hosted/served_health_facilities.mapserver'., Access to this resource is forbidden, regardless of authorization."
Knowing that I publish a feature class that is in relation with another table through relationship class in the project Geodatabase as shown in the first screen.
I highly appreciate your support on this issue very soon, since I have to meet the deadline.
Have a nice day!
sxw_eaglegis
Hi Mohammed, a few questions about this - Is there already a map service published to your ArcGIS Enterprise site called "served_health_facilities"? What type of authentication does your portal use? is it built-in users? and I guess your user has publisher rights?
MohammedAlhessi4
Thank you @sxw_eaglegis  for your response. Let me answer you questions as follows:
I have searched My content, but there is no one with the same name.
I am not the administrator of my account, but I can conclude it is Active Directory Authentication because I use the same way and the same login credentials when I log into other applications.
I didn't understand this.
Yes I am creator with Publisher role.
I would like to confirm that the problem is when I publish the feature class with its related table. If there is no relationship class in the geodatabase, It works without any problems.
dhowes1
I am having an identical issue.  Was a resolution found?
laubert
I am having this issue as well.
StatusMessage: Server Response: ERROR: code:403, User does not have permissions to access 'hosted/cable.mapserver'., Access to this resource is forbidden, regardless of authorization.
MichaelMixon
Several folks in my organization receive this error when attempting to overwrite or publish a service in Enterprise 11.3 using ArcGIS Pro 3.3.0. After the error is thrown the existing service is corrupted and must be recreated. I'm simply adding to the list of people that have encountered this error with no solutions.
AndreasB
I'm encountering the same issue. Is there a bug/solution for this?
dhowes1
No formal resolution from ESRI I'm afraid - we had a ticket but they failed to replicate it.
I have a suspicion that it is due to sharing though - I still get this error occasionally when I try to publish without sharing to anyone and it seems to go away if I share to a single group.  Would be interested to know if you were sharing with anyone or not.
