Exporting feature fails to include all fields
7575
10
05-21-2024 11:17 AM
MichaelSeymour
I just upgraded to ArcGIS Pro 3.3.0.
I'm running into an issue exporting features using the typical right click on feature in Contents --> Data--> Export Features. Previously, the output feature would include all the fields from the source feature, but now I'm getting a random assortment of fields that don't include all fields but *do* include previously deleted fields from the source feature...
My workaround is bringing the source feature into ArcMap and exporting the feature that way. It works fine in ArcMap...
Any ideas?
Thanks!
Michael Seymour
mseymour at wlf.la.gov
DanPatterson
MVP Esteemed Contributor
BUG-000154896 for ArcGIS Pro (esri.com)
apparently, but I don't use your shorcut, but the Featureclass to Featureclass tool (which they recommended as a 'workaround' for some strange reason, instead of the first tool to use)
... sort of retired...
DanPatterson
sounds familiar
Solved: Pro not exporting all fields of hosted feature lay... - Esri Community
see if this matches your case
MichaelSeymour
Thanks for the quick reply! Yep, I saw that post, too, but it sounded like the bug had been fixed, no?
DanPatterson
MichaelSeymour
Yep! That seems to work! Thank you! I really appreciate the assistance!
JasminePrater
I saw that this bug was fixed in earlier versions of ArcGIS Pro, but we are using 3.3.1 and still encountering the issue.  It's not consistent, but our current workaround is to export the feature to the project geodatabase and then export the table from the new feature.  Both my coworker and I have had the issue over the last two days, but haven't seen it for a month or two before this.  While the issue is infrequent and our workaround acceptable, it still persists in the ArcGIS Pro 3.3.1.
DanPatterson
you should report it, they will want to examine data that you are using that throws this error
Goldendelicious
I'm running Pro 3.4 and this is happening to me. Can confirm the workaround of modifying the field map output forces it to output the fields you want/need.
GaryMartin1
I'm running 3.5 with the latest patch and it's still happening.  The field not exporting is an indexed field.
AniketMisal
Is anyone facing this issue in 2025? I am using ArcPro 3.3.0. I am joining an excel table to a layer and exporting the features but it only exports the original fields and not the joined ones.
