export symbology from one project map to another project map
14084
13
09-07-2023 10:53 AM
BarbaraDabney
ArcGIS Pro, Beginner, version 3.1
Is it possible to copy symbology from one project map to another project map? I want the "FROM" symbology from the MWSD_STRUCT layer  (see screenshot) to import into the "TO" map NODE layer. (see screenshot).
I tried to set the CAP symbol based on the formatting but I could not find the right symbol and it just didn't work.
I saw something at the Esri Conference that I thought said that I can do this so I don't have to recreate the entire symbols one by one now but don't know how. Any help is appreciated.
Barbara
Tags (1)
BarbaraDabney
This seemed to come to me instead of the intended person?
DavidGray1
Hi Barbara; I suspect you got a notice because you were the originator of the entire thread to begin with? Regardless, I hope the continuing thread is informative!   Dave
DavidGray1
Hi Vikas;  I just recently did find a method that works. While exploring ArcGIS Pro 3.2 topics, I found the instructions for "Import symbology from another layer". This method works and is a simpler method than the alternative set of instructions called "Export symbology from one project map to another project map". The Import method does not involve exporting a .lyr file of the feature for which the symbology is desired and works for within the same Project. The Export method I suspect is the method to use when wishing to export a symbology and bring into a different and separate Project. That may be a critical difference in the applicability of these methods, although it remains to be explained why it wouldn't change any symbology when importing from the exported .lyr file.
However and as a heads-up, the Import symbology instructions say that the menu box that appears says "Apply symbology from layer" when in actuality - after hitting import on the Feature Layer tab, the menu box says "Import symbology from layer". Also the instructions say to hit "Run" when the actual menu box says "Apply". A bit confusing, but it works.
Thanks all;   Dave
BarbaraDabney
Thanks but this is going to the wrong recipient I think. I am not Vikas.
