Export Features results in consolidation to single location
3130
15
12-02-2024 09:05 AM
JasonWeis_Westwood
Since updating ArcGIS Pro to version 3.4.0, when I attempt to export a selection of points collected with Field Maps in an ArcGIS Online hosted feature layer to a file geodatabase feature class, all of the exported points are moved to a single location (the location of one of the exported points).  This occurs with both a right-click on the layer name (with Data: Export Features), and also with starting directly from the Export Features geoprocessing tool. The attributes appear to export correctly - it is simply the location of the point that gets modified.
I have been using this workflow frequently in the past (exporting a subset of collected points to a project-specific geodatabase), and the points always exported to the correct location, even if specifying a new coordinate system. This "consolidation" did not occur until I performed the v3.4.0 update. (The display cache was cleared as a troubleshooting step, but had no impact on the error.)
When I tested this with other ArcGIS Online point data that was NOT populated using Field Maps, the points exported correctly. Likewise, when exporting selected points from a local source (file geodatabase), the points also exported correctly. Performing the operation on a workstation with version 3.3.1 did NOT have the same issue - the various points were exported to their proper locations.
Has anyone else encountered this potential bug?
RobertWagner3
this did not resolve the issue
FourCornersMapping
This BUG-000172816 is apparently addressed in 3.5, but as of today there are only patches for 3.4 available. The workaround suggested by Esri is to use the Copy Features tool, which maintains attachments.
luckachi
This issue is still occurring in 3.4.2 however, for me, it has been with polygons. Hopefully 3.5 will address this finally.
GC_GIS
Have you figured out a solution to this issue?
AJ_Abshire
I still haven't found one unfortunately - I'm still getting this bug.
GC_GIS
I ended up getting it to work by unchecking "maintain attachments" before exporting.
