Export FC to new FC with Default Field Values and Null Fields - It's doing what??
891
07-14-2023 12:01 PM
Labels (2)
Todd_Plank
Is this how Export FC or FC2FC supposed to work?  Very concerning
The issue that I ran into is when exporting features from a geodatabase where a field has a default value set and has records that are NULL. What I am seeing is that any records that are NULL will be populated with the Default field value when exported to another geodatabase with ArcPro. I did the same test in ArcMap and NULL values were not populated.
Example: Here is a manhole with a field [test] where all the records are NULL
In Fields View I set the Default to 123
Exporting the feature layer to another feature layer populates that Default value in all the records that are NULL
There is no warning that the records with NULL values will be changing.
We ran into this problem while receiving a geodatabase from another source where Default values were set in the records and we exported from those feature layers, thus getting different attribute results in our queries.
Todd_Plank
Esri is responding that this is a Bug and that newer versions of the software are not functioning as described.
I am using 3.0.2.  Esri tested in 3.1.2 and says it works in that version.
