When I update and save an xlsx sheet, the changes are not reflected in Arc GIS PRO. Does anyone else have this problem? Has anyone found a specific method to making the changes reflect?
I usually have to turn off PRO and then restart the program for the changes to be reflected. That said, recently I noticed that even turning off the software and restarting that the changes don't reflect in PRO.
Please note, I make the change in excel. I save the file. I close Excel.
In PRO I remove the old sheet from the Contents pane and refresh the homefile the spreadsheet is in. I also refresh the folder the spreadsheet is in. And I do this in a variety of order.
It also seems that just being patient does not work.
I have had this problem for many PRO versions and currently am running 2.5.0
