Error migrating python label expression from Arcmap to Arc Pro
2292
10-27-2021 10:26 AM
JoanHickey
I have a python label expression that works in arcmap, but when I try it in ArcPro, I get an AttributeError:  "NoneType' object has not attribute 'strip'.  I think this might happen because there are null values in my data (just a guess).  Here is the expression:
def FindLabel ( [PAD_addr],[UnitsRes],[NumBldgs]):
S =[PAD_addr].strip()
i = S.find('(')
nres = long([UnitsRes])
nbldg = long([NumBldgs])
if i == -1:
tmp = S.replace('::','\n')
elif i > 0:
tmp = S[0:i]
if nbldg > 1:
tmp2 = ' on lot)'
else:
tmp2 = ')'
if nres == 0:
return tmp + '\n(no res units)'
elif nres == 1:
return tmp + '\n(' + str(nres) + ' res unit' + tmp2
else:
return tmp + '\n(' + str(nres) + ' res units' + tmp2
Any help would be appreciated.
JoeBorgione
@JoanHickey - this is  a better solution for you.
JoeBorgione
Trap for null values and use a pass:
if <!field!> is null:
    pass
else:
   #do the rest of the mojo
(not tested...)
DanPatterson
MVP Esteemed Contributor
or query your data for null values, switch the selection, then use your function
Code formatting ... the Community Version - Esri Community
to make code easier to read
... sort of retired...
JoeBorgione
JoanHickey
It was actually
if <!field!> == None:
pass
Thanks for the help.
Happy retirement!
