Error: ArcGIS License Manager must be upgraded to support this ArcGIS Pro version
2086
6
03-21-2024 05:27 PM
anbinh
Hi Community,
We just have upgraded our License Manager to the latest version at 2023.0. We have ArcGIS Pro 2.9.5 to connect with this License Manager. According to the Esri documentation Supported software products—License Manager Guide | Documentation (arcgis.com), it should not have compatibility issue.
However, the user encountered an issue saying "The ArcGIS License Manager must be upgraded to support this version of ArcGIS Pro. Please contact your organisation's License Administrator to ensure that the ArcGIS License Manager version is up to date."
Am I missing any setting here? Is there anything I can do to resolve this issue?
Regards,
AB
MichaelVolz
Esteemed Contributor
Can users upgrade their own machines or is that locked down?
Are you sure the user did not try to install a newer version of Pro that needs a higher version License Manager?
anbinh
Hi Michael,
The license manager is already at the highest version.
The ArcGIS Pro on the user side is currently locked to 2.9, so we cannot upgrade the ArcGIS Pro to the latest version.
If as the documentation says, License Manager 2023.0 should still be able to support Pro 2.9. Just that the error message contradicts with the theoretical compatibility here.
GISFunctionalGroup
Hi there,
Did you get the solution for the issue. We are facing the same issue after upgrading the LM to 2024 version in the server machine. Users are locked with 2.9version in their machines.
Any suggestions /solutions are highly appreciated
Regards
GIS Functional Group
anbinh
I can't remember exactly what solved the issue. In my case, the real trouble-maker was the flexnet licensing service running on the same server with conflicting ports. Hence, we needed to lock the port and suggested client to move flexnet licesing to another server. (It does not seem that flexnet port can be locked, so we had to lock ArcGIS licensing port.)
Anbin
GISFunctionalGroup
Thanks for the feedback. Meanwhile we resolved the issue by assigning the fixed port number for ArcGIS licensing port on license server.
