In an ArcGIS 10.8.1 environment and st_geometry in oracle 19c whe trying to run "Create spatial type" it givs the following error: db_get_dbms_release:: Unknown DBMS Release (19.0.0.0.0) higher than 18c detected using DBMS_UTILITY.DB_VERSION. SGA_Param - Open_Cursors: 1000 SDE_Oracle Error: 6598 ORA-06598: privilegio INHERIT PRIVILEGES insuficiente ORA-06512: en "SDE.ST_GEOMETRY", line1036
