error 00396 - Share Content to Portal
880
04-07-2025 07:16 AM
Labels (2)
desiree
I've created a used "import 3D object" from the "geoprocessing" toolkit in a local scene to place a 3D object at a certain geo-location. The 3D object I want to share/export to ArcGIS Online using "Share as a web layer" has the following info:
Data Type  File Geodatabase Feature Class
Database  C:\Users\user\Documents\ArcGIS\Projects\MyProject4tesrt\MyProject4tesrt.gdb
Name  test
Alias  test
ObjectID  32-bit
Feature Type  3D Object V2 (Simple)
Geometry Type  3D Object V2 (Multipatch)
Coordinates have Z value  Yes
Coordinates have M value  No
Attachments  No Attachments
Feature Binning  Disabled
Compression  Uncompressed
Vertical Units  Meter
Minimum Client Version  3.1 / 11.1
But something fails and I get the error: 00396: The dataset version is later than is supported by your server. Minimum version: <value>
How can I solve this? I've already checked out this page: https://doc.arcgis.com/en/allsource/1.1/production/00396-the-dataset-version-is-later-than-is-suppor...
My idea is to host a digital twin (3d model of a building) and then update it with new 3D objects using the python API. The first step would be to have our 3D model in a suitable datatype and from what I've heard that would be a "hosted feature layer with multipatch geometry"?
DanielFox1
Hi @desiree
The error message is noted here in the following article
You need to be aware of where and what version your data is coming from, also the version of ArcGIS Pro and environment you are attempting to publish to.
