error 00396 - Share Content to Portal
5666
8
03-21-2024 12:04 PM
BelindaDow
Hello, I recently started a class in ArcGIS pro, I have Pro 3.2.2 installed. I am working with school provided data and tried to share content to portal. The lesson goes over the connecting to/share to portal. I selected share as web map and had two errors. I corrected one, on allowing assignment of unique numeric IDs for sharing web layers, but I do not understand how to fix the second, error 00396 The dataset version is later than is supported by your server.
Is this something to do in the version it was created/shared by?
Instructor said I would need to log into their portal to get the right outcome, but how is this fixed in a work situation. Can it be?
-Any information greatly appreciated.
Eugene_Adkins
Logging in to their portal would probably reference a different server, and this server could be a compatible version to the dataset you're using to create the published service. If there are multiple portals to sign in to then the source/destination could affect the workflow. If there's only one portal to sign in to and publish to, then it sounds like some incompatibility with the server version the portal is using.
Hope that helps.
BelindaDow
Pardon the delay. So I have gone through ArcGIS Pro Beginner, Intermediate and Advanced the last few months. So, problem was that since I was using the schools data, logging into their computer, for remote access, then logging into their ArcGIS online portal is where I received that error.
The multiple sign in/log was the issue. I had to be signed into both to be allowed to run any project, the confusion was since I already had the data on my pc at home, I assumed I could run on my end.
Moving forward, being aware of source/destination could affect my workflow, and making sure about compatible versions for dataset analysis.
I honestly don't remember having to sign in so many times. 😉
Robert_LeClair
Esri Esteemed Contributor
This page has a description of the error message and a few solutions to consider.
davedoesgis
I just ran into this on Pro 3.2 and Portal 11.1. I tried creating an FGDB in an older version (10.0 was the latest non-current version) and saving the feature class there. I still got the same error.
I didn't have any field types that matched those in that help doc, but there are a bunch of date fields in my feature class. I deleted all the date fields and it published to Portal just fine. That's not an acceptable solution, but at least I've narrowed it down a bit. For a temporary work-around, I created a text field to hold the date, calculated it like this, and then deleted the date field:
I was then able to add a date field on the hosted feature layer, add it as a layer in Pro, and calculate the field based on the text value:
This is a lot of shenanigans, so not a good workflow, but I guess it technically works. I'll post an update if I figure anything out, but I need to switch gears at this point.
MattStarryACE
This should be a bug. I also have only "regular" fields but can't publish a web layer from Pro 3.2.2 to Enterprise 10.81 and I believe it is because it has date fields.😖
davedoesgis
jschuckert
I am also encountering this error, however it is with Pro 3.2.2 publishing to Enterprise 10.9.1 publishing a service including a Query Layer. If I make no changes to the QL it publishes fine, however I need to modify some fields in the service so as soon as I re-validate the query or make any changes it errors out and won't publish (overwrite or new). I checked, there are no new data field types involved in the QL layer.
Has anyone updated their Pro version (3.3.1 latest) and had any success bypassing the issue? I see a similar recent bug logged but with a view:
https://support.esri.com/en-us/bug/unable-to-publish-view-to-web-service-after-registering-bug-00016...
Robert_LeClair
Related to BUG-000166759 - "Unable to publish view to web service after registering with geodatabase and returns the error message "Error: 00396: The dataset version is later than is supported by your server. Minimum version: <value>."
This bug is related to
ENH-000163896: Add an option to explicitly format the time in standard precision in Register with geodatabase GP Tool. After Registering with geodatabase a view containing Date fields from ArcGIS Pro version 3.2.2, there is an error message when trying to publish to ArcGIS Enterprise version 11.1 or earlier:00396: The dataset version is later than is supported by your server. Minimum version: <value>
The cause of the malfunction is that the Date field is in high precision after Register with geodatabase.  A workaround is not registering the view to the geodatabase.  By doing this, the publishing workflow should be successful.
