Element pane of ArcGIS Pro 1.2 Beta changing Text property when only Name should change
2455
01-24-2016 10:21 PM
GraemeBrowning
I've been noticing some quirky behaviour from the Element pane of ArcGIS Pro 1.2 Beta.
As an example try the following:
  1. Open ArcGIS Pro 1.2 Beta
  2. Create a New Project using the Map.aptx template.  I called mine "test" and placed it in "C:\Temp"
  3. INSERT a New Layout.  I chose A3 from the ISO - Portrait category.
  4. INSERT a Rectangle Text element
  5. In the Element pane under Properties and General, highlight and overwrite the Name from "Text" to "NewText"
  6. The text in the Rectangle Text element on the Layout changes to "NewTextText" - I don't think it should change at all because all I am trying to change is the Name property of the element and not its Text property
Can anyone else reproduce this?
DavidBarnes
I cannot reproduce this with current development builds. I believe this is something we fixed after the beta went out.
Thanks for reporting it!
DavidBarnes
