Dynamic text in reports not displaying
1327
01-29-2024 01:32 PM
JuliaMoloney1
When exporting a report in ArcGIS Pro, some of the dynamic text fields aren't displaying correctly. The dynamic text fields are linked to a point layer which is populated via Quick Capture.
The fields that are system generated or calculated (such as field worker, eastings, northings, and date/time) are appearing as expected. However, any user-entered fields are displaying just as the field name eg {Sample_name}. I have tried separating the field-values into individual text boxes but am still getting the same issue.
I've read there are known bugs for dynamic text in reports and that it will be patched in the next update - is there any indication on when that will be, and will it fix the issue above?
AlyciaRajendran_esri
Hi @JuliaMoloney1,
Can you email me more info? Thanks! [email protected].
- Alycia
