Drone images not lining up in Orthomosaic
1426
04-30-2017 04:55 PM
Jeremy_Moore
Please be gentle I'm very new to making orthomosaic images in ArcGIS Pro. I was able to completely go through the entire process that is laid out in the help which can be found here: http://pro.arcgis.com/en/pro-app/help/data/imagery/ortho-mapping-in-arcgis-pro.htm and I was able to make a final orthomosaic product.
The issue I'm having is quality control before the mosaic is generated. Some of my images do not line up 100% accurately with each other. So my main question is how do I fix this? I assume it has something to do with tie points and check points.
Thank you in advance!
