Drawing Alert leads me to Labeling Expression error ?
1696
6
04-18-2025 10:15 AM
DEAF_PROBERT_68
Honored Contributor
Before I dive into more detail. I have an issue with a layer that somebody wrote this expression into this labeling expression.  I have the Drawing Alert that tells me . I am trying to understand this and I am not sure how to fix it.
The layer I had was from an original layer came from the upper management and they did this for the whole country and I had to use it to clipped it to smaller area for our project.   So when you clipped the layer , I believe some of the expression did not work in the label expression.
So here is the Expression from the Labeling section is what I have here from an original layer:
def FindLabel ( [TRAIL_NO], [ADMIN_ORG], [MANAGING_ORG], [TRAIL_NAME], [NATIONAL_TRAIL_DESIGNATION] ):
    if [ADMIN_ORG].startswith('02'):
        s='.'
        if [ADMIN_ORG].startswith('0201'):
            return [TRAIL_NO] [2:]
        else:
            return [TRAIL_NO].split(s,1)[0]
    elif [ADMIN_ORG].startswith('0919') or [ADMIN_ORG] .startswith('0922') or [ADMIN_ORG] .startswith('0903')or [ADMIN_ORG] .startswith('0913'):
    elif [ADMIN_ORG] .startswith('0909') or [ADMIN_ORG] .startswith('0907'):
        return [TRAIL_NO] [2:].replace('-','')
    elif [ADMIN_ORG] .startswith('0904'):
        return [TRAIL_NO] [1:]
    elif [ADMIN_ORG].startswith('0915'):
         return [TRAIL_NO][4:]
    elif [ADMIN_ORG].startswith('08'):
       if [ADMIN_ORG].startswith('0805') or [ADMIN_ORG].startswith('0810'):
            return [TRAIL_NO].replace('TRBS','').replace('TR','')[1:]
       else:
    elif [ADMIN_ORG].startswith('04'):
        if [ADMIN_ORG].startswith('0419'):
        elif [ADMIN_ORG].startswith('0402'):
            return [TRAIL_NO][:3]
        elif [MANAGING_ORG].startswith('0402'):
        elif [ADMIN_ORG].startswith('040702') and [TRAIL_NO].startswith('32000.'):
            return [TRAIL_NO].replace('32000','').replace('.','')
        elif [ADMIN_ORG].startswith('040702'):
            return [TRAIL_NO][2:]
        else:
           return [TRAIL_NO][1:]
    elif [ADMIN_ORG].startswith('0303'):
    elif [MANAGING_ORG].startswith('031204'):
        return [TRAIL_NO].replace('MT-','')
    else:
        return [TRAIL_NO].lstrip("0").replace('.', '-').replace('TER-','').replace('TRD','')
I have the clippped layer here and I have looked into the attributes and I can see some of the split it mention in the expression and yes I can see some of the numbers like this 157.2 or "Name of trail".456
The Problem is the error that tells me
File "<expression>", line 1, in <module>
File "<string>", line 7, in FindLabel
AttributeError: 'NoneType' object has no attribute 'split'
I am clueless here and I am not sure what the line 7 is and I am not sure where to find it.
Please excuse my grammar here. I am deaf and I try my best  to understand how it works and it will help me to understand better down in the road should I came up the same thing in the future...
Thanks GIS friends !
I am in the VDI, Citrix, and ArcGIS Pro 3.3.4.
KenBuja
MVP Esteemed Contributor
It's difficult to follow the logic of this code. When posting code (especially Python code, where indenting is important), please use the "Insert/Edit code sample" button.
DEAF_PROBERT_68
Honored Contributor
Ok will do.
KenBuja
Please fix the indenting
KenBuja
If a record contain a null value in [TRAIL_NO], then you'll get the split error. You have to check whether that attribute is not null before attempting to split it (line 7).
        s='.'
        else:
            if [TRAIL_NO]:
            else:
                return "TRAIL_NO is null"
DEAF_PROBERT_68
Honored Contributor
I fixed it and it worked; however on line 2 which I am not sure about but I can see the Admin_Org has null and I don't know how to include it in the code ?
def FindLabel ( [TRAIL_NO], [ADMIN_ORG], [MANAGING_ORG], [TRAIL_NAME],[NATIONAL_TRAIL_DESIGNATION]):
        s='.'
        else:
            if [TRAIL_NO]:
                return [TRAIL_NO]
            else:
File "<string>", line 2, in FindLabel
AttributeError: 'NoneType' object has no attribute 'startswith'
And here is the screenshot for the field name here is
KenBuja
You'll have to do the same thing with any field that a text function (split, startswith, replace, etc). Since most of the conditional lines are testing [ADMIN_ORG], you should put that at the beginning, like this:
    if [ADMIN_ORG]:
You can put that on one line, like this:
elif [MANAGING_ORG] and [MANAGING_ORG].startswith('031204'):
