Downloading MMPK with ArcGIS Pro
2003
07-27-2017 12:58 PM
BikeshMaharjan1
I am trying to download the mobile map package through ArcGIS Pro Desktop Application. After filling the parameters, I get an error that says, "The layer type is not supported in runtime content: Map/World Imagery Failed to execute (CreateMobileMapPackage)." The map just has a World Imagery base map layer. I have also tried maps with (export) but get the same error.
I can download the same map from my portal with ArcGIS .NET Runtime SDK with some C# code though but I am trying to figure out how I can download it through ArcGIS Pro.
Thanks!
MarkBockenhauer
The Create Mobile Map Package tool currently supports packaging Feature Servicesa and local vector data.  Basically, only supports data sources that can be converted to a file.
ArcGIS Pro 2.1 will support Rasters.  .TPK files and Imagery files.   Map Services like the Esri Basemaps will not be supported for inclusion in a Mobile Map Package.
