Double symbology in ArcPro
978
11-09-2021 02:37 PM
TamraSteens
Hello,
I am having trouble getting double symbology in ArcPro. When I'm in 'Vary symbology by attribute', the fields are limited to only a few, & not the ones I need. Any help would be appreciated!
Thanks
DanPatterson
MVP Esteemed Contributor
Again.... Attribute-driven symbology—ArcGIS Pro | Documentation
is everything enabled? What are the field types? are there any joins?  if there are joins, did you try to make the join permanent?
... sort of retired...
TamraSteens
Yes, everything is enabled. No joins. The fields are text (not showing) versus Long or Double. I'm just trying now to create a new field for what I need in Long or Double. Here goes...
TamraSteens
That didn't work, as I need it to be a text field. It looks like that could be the reason why though, 2nd symbology can only be numerical? Any ideas??
DanPatterson
show what is in your table and what fields you are using so people can try to replicate your steps
BranislavBlagojevic
That's right! Does not work with the Text field; BUG-000104316! More about Setting up the attribute-driven color in symbology... - Esri Community
