Don't add map layers by default (World Topographic Map and World Hillshade)
1834
07-08-2022 08:07 AM
Bud
Esteemed Contributor
I create multiple ArcGIS Pro projects per day. And each time, I need to remove the default map layers: World Topographic Map and World Hillshade. I don't ever use those layers...I always use in-house layers.
Is there a way to prevent those layers from being added to my map by default? That would be more convenient than always removing them.
I'm aware that I can save a project and use it as a sort of "default blank map". And then save-as to create new projects, as required. But I'd rather just create new projects from scratch — without any layers added.
Thanks.
DavidSolari
MVP Regular Contributor
Any luck modifying this option?
DavidSolari
Bud
That worked. Thanks!
