Domains Not working or showing up in ArcGIS Pro 2.9.1 ?
6962
03-15-2022 03:48 PM
DEAF_PROBERT_68
Honored Contributor
Feeling frustrated here....
You know in ArcGIS Desktop, I was able to create Domain and Subtype and it was easy to follow.  As I am learning more about ArcGIS Pro 2.9.1 and I had to copy the geodatabase from previous work and I am re-creating it again to improve the fields.
Problem is that I did follow the instructions here: Create and manage domains—ArcGIS Pro | Documentation
and I know it should work because I did in ArcMap. However, in ArcMap, you would have to use Editing Toolbar to enable to have the Attribute Table open and use the drop-down  to choose which  to populate from the list
See an example from ArcMap :
But in ArcGIS Pro, I was not able to see that and wonder why.  ? Did I miss something simple here ?
Should it be easy around to fix this issues ?
So here is what I did;
I highlight the layer that has these Domains  then open the Attribute Table to show the status of each Doman :
Screenshot of my Fields with Domains :
DEAF_PROBERT_68
Honored Contributor
BINGO !!!!!!
While I post this and been trying figure it out.....
Found out !! is that ensure your layer is enable turn on in List by Editing !!!!
It worked !!!
AND see it is simple as it should be !
Yay
DEAF_PROBERT_68
Honored Contributor
BINGO !!!!!!
It worked !!!
Yay
DEAF_PROBERT_68
Honored Contributor
If yours layer has been disabled ,  here is the info to get it fix..
https://pro.arcgis.com/en/pro-app/latest/help/editing/manage-editability.htm
