Disappearing Raster (Satellite Imagery)
1233
18
01-31-2024 09:29 AM
MARVINLEWIS
I created a web map in ArcGIS Pro which was uploaded to ArcGIS Online. Upon opening the web map in ArcGIS Pro, I realized that whenever I zoomed into the map, the satellite imagery disappeared (and even the basemap). Everything apart from the point layers just turns white. How can this be resolved?
Ed_
by MVP Regular Contributor
Could be a scaling issue, might want to check the visibility range.
Question | Analyze | Visualize
MARVINLEWIS
Much thanks for the response, but, that was actually the first thing I did and nothing came out of that.
MARVINLEWIS
Ed_
No worries, what browser are you using? Chrome?
MARVINLEWIS
Yes, I am using Chrome. You suggest trying a different one?
Ed_
No Chrome is the recommended browser. May be delete the web map and republish the map again from Pro. Another way around could be to publish the layers one by one to AGOL and add them to Map Viewer one by one. Like publish one layer then add that to Map Viewer and see if it's working fine. The publish the next layer and add that to the web map and see if it's working and so on.
MARVINLEWIS
Ok, much thanks, I will try this and see.
Ed_
Good luck and Happy Friday.
MARVINLEWIS
Ok, I just tried it and still the problem remains consistent.
