Different images for each polygon in pop-ups
1929
01-23-2017 10:23 AM
dustyrose
I am trying to create a map in ArcGIS Pro in which you can click each individual polygon and then have the pop-up show an image of that area. Am I going to have to make each polygon its own layer in order to give each polygon its own separate pop-up? Or is there a way for me to set different images in the pop-ups for each separate polygon? Or is there a way I can add the image hyperlinks to the attribute table and then have the popup show the image (NOT the link)?
Tags (3)
TimOrmsby
Hi, you can do it by putting the image URLs in the attribute table, as you suggested. Then configure the layer pop-ups like this:
  • Right-click the layer on the Contents pane and choose Configure Pop-ups.
  • At the top of the Pop-ups pane, click Image.
  • Click the pencil icon to edit the image properties.
  • In the Image Options, click in the Source URL box. Click the Field drop-down menu and choose the field name from your table that stores the image URLs. In this example, the field name is IMAGE_URL, but it can be whatever you want.
  • Click the Back button on the Pop-ups pane to apply the changes.
Now you should see the unique images associated with your features in the pop-ups.
Tim
ThomasGilbertson
Excellent guidance!  Thank you!
