detect object using deep learning deep learning libraries installer for ArcGIS pro 3.1
1314
04-06-2023 03:23 AM
Kris_AB
Hello everyone,
I am using detect object using deep learning model. I have ArcGIS Pro 3.1, Image analysts extension, installation of deep learning libraries installer for ArcGIS pro 3.1, building foot print extract -USA.
When I ran the geoprocessing tool, i received  the following message.
my GPU seems fine.
Did I miss anything? I already installed deep learning frameworks.
is Deep Learning Python API (CNTK, TensorFlow, and so on) installed separate installation?
002667: Cannot load python module.
ArcGIS Pro 3.1|Other versions
Description
This tool requires that the deep learning frameworks are installed.
Solution
Make sure you have the right Deep Learning Python API (CNTK, TensorFlow, and so on) installed. See Install deep learning Frameworks for ArcGIS for more information.
Unable to initialize python raster function with scalar arguments. [C:\Users\user\AppData\Local\Temp\ArcGISProTemp2200\usa_building_footprints (1).dlpk\ArcGISInstanceDetector.py]
File "C:\Users\user\AppData\Local\Temp\ArcGISProTemp2200\usa_building_footprints (1).dlpk\ArcGISInstanceDetector.py", line 141, in initialize
ChildInstanceDetector = getattr(importlib.import_module(
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 972, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\__init__.py", line 3, in <module>
from arcgis.auth.tools import LazyLoader
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\auth\__init__.py", line 1, in <module>
from .api import EsriSession
PavanYadav
@Kris_AB it does look like the tool cannot find the right deep learning libraries. I know it's an old post but wondering if you have been able get it fix?
A side note: We have an ArcGIS Image Analyst dedicated community and here you might get response sooner.
Cheers!
Pavan Yadav | Product Engineer - Imagery and AI
Esri | 380 New York | Redlands, 92373 | USA
https://www.linkedin.com/in/pavan-yadav-1846606/
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
