Database view not showing attributes in popup
1225
04-12-2024 03:36 AM
AndyIngall
Hello
I have created a database view via SSMS which works fine, this has been registered with the geodatabase and the data loaded into ArcGIS Pro.  All features are shown on the map as expected
When I look at the attribute table, everything looks correct with all expected attributes populated with data, however when I click on a feature within the map to view the data as a pop up, the data is not displayed, however the field names are shown but the data is blank.
Anyone have any ideas what could be wrong.
Thanks in advance..
Tags (3)
Robert_LeClair
Esri Esteemed Contributor
@AndyIngall  - there is a great Technical Support article here that may be a start for troubleshooting the popup issue.
Bud
1. What version of SQL Server, geodatabase, Enterprise, and Pro?
2.Have you tried creating a new unregistered view? Does the issue happen with it too?
3. What is the SQL definition?
4. Can you provide a screenshot or video of the issue?
5. What do you mean by “the data loaded into ArcGIS Pro”?
SivaG
Hi, I am also facing the same issue. Attribute information is visible in the attribute table but not in the popup window. Did you find any solution for this issue? The article shared by Robert is not related to this issue.
