Good morning,
I was trying to setup my database connection but I run into the following error.
I am using the same credentials and Instance that I use for ArcGIS Desktop. Any idea what could be the issue?
Tim
Hi Tim,
It looks like you may need to install the 64-bit Oracle client, as ArcGIS Pro is a 64-bit application. You can download the appropriate client form the Oracle website.
Here is a link to Oracles Instant Clients
Here is some more information related to setting up a database connection in Pro:
Look at the section on "Setting up a connection to Oracle"
Please post the results after installing/configuring the 64-bit client.
-George
Geodatabase Managing Data Esri Technical Support
I have figured it out, I need to install the 64bit client.
Thanks George,
this is a better answer
