I custom made a symbol in Adobe Illustrator and have exported it to BMP, PNG, and JPG and even at killer resolutions and 200MB the quality of the symbol is terrible and pixelated. I even increased my Illustrator drawing to a very large size and tried that but it's not doing anything but make my drawing speed slow. I found a property under Appearance for quality and this helped but it's still not crystal clear like the ESRI symbols.
2 questions:
Does Appearance quality setting effect the symbol on the actual print? What does it really do when I use Draft quality on the final product?
How do I get a stunning custom symbol? the resolution issue is killing my map!
I never thought about downsampling before! That was it! I started at 300x300 as my artboard size and it was apparently too big but I went to 6000x6000 thinking to go bigger. I just now reduced it to 100x100 and exported at medium 150 resolution and wow! That's what I wanted! Thanks Dan!
glad it work out Jacqueline
Jacquelline,
Could you attach a screenshot of what your symbol looks like exported from Illustratror compared to how it displays in ArcGIS Pro.
Mark
I got it. I was going bigger and bigger thinking that was my issue but it was the opposite. I reduced my Illustrator artboard to 100x100 points and it solved the issue! yay!
I wasted so much time thinking a higher image size would naturally display better. Dropped from 1200x1200 pixels to 500 and now it looks amazing. Thanks to the folks here
