curve problems
1415
05-21-2025 12:05 PM
MohamedIsmael
I have a problem when drawing polygons when creating a curve. Sometimes, at the end of the curve, the line isn't smooth. There's a break, like the one in the image.
If I have a lot of data, I want to discover all the problems that are similar to the image. Is there a way to use attribute rules or any other method that I can easily discover instead of visually reviewing the edges?
Tags (3)
AyanPalit
@MohamedIsmael Thanks for posting a sample image. I don't see a break - do you mean a gap when you zoom in close? Perhaps a digitizing error when constructing the polygon?
Data Reviewer has Unclosed Polygon that can identify such issues? You may find/develop a script to identify this as well.
Ayan Palit | Principal Consultant Esri
MErikReedAugusta
MVP Regular Contributor
I also don't see a gap.  But I do see a kink, where the curve just isn't smooth.  That's likely going to be much harder to locate.  I don't personally know of any ways other than the good old "Mark I Eyeball" method, though someone here might have figured out a script to analyze the curves at all of the nodes of each polygon.  I can't imagine it'd be too efficient a script to run, though...
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
BillFox
MVP Notable Contributor
are you using COGO?
maybe missing that "reverse" tangent curve
maybe it is a non-tangent curve
fillet tool https://pro.arcgis.com/en/pro-app/latest/help/editing/create-a-fillet-between-two-segments.htm
find dangles https://pro.arcgis.com/en/pro-app/latest/help/data/validating-data/find-dangles.htm
