Creating “toolbox” in the ArcGIS Pro by right clicking the folder,
6007
14
09-12-2015 01:42 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why one can’t create “toolbox” in the ArcGIS Pro by right clicking the folder (and then choosing “new toolbox” from context menu) the same way we do in the ArcGIS Desktop.
However, one can choose the target folder to save the toolbox by using insert>toolbox>new toolbox
Thank you
Best
Jamal
Jamal Numan
Tags (1)
JenniferMcCall4
Hi Jamal,
What version of Pro are you on?  I'm on Pro 1.1.0 and that functionality is there.  Maybe you require an upgrade or a fresh install of Pro.
Cheers,
Jennifer
JamalNUMAN
Thanks Jennifer.
Are we missing now (in ArcGIS Pro 1.1.0) all other elements that are used to be created by right clicking the folder in ArcGIS Desktop?
Jamal Numan
JenniferMcCall4
Hi Jamal,
I assume most, if not all, of the functionality from that list is built within Pro.  How to access the functionality has probably changed in Pro a bit since it's a new application.  For instance, adding a File Geodatabase from the Project Pane is done by right-clicking the Databases folder now and choosing the location (and of course there is the option to add one from the Insert menu as well).
I'm taking a guess, but I assume this was changed because it stores the connection to that file geodatabase in the Databases folder for easy access, and also to organize the connections for the project.  After working with ArcMap for so long, it can take some time to become adjusted to the changes, but it does make working with "projects" much easier.
David
by Esri Contributor
It's actually rather simple.
To create a new toolbox, right-click on "Toolboxes".
If you want to create a new geodatabase, right-click on "Databases".
JamalNUMAN
Many thanks guys for the help,
It does better make sense if we just right click and find all the functionalities.
Jamal Numan
