Creating new shp file by drawing polygons
5663
10
01-28-2016 02:40 PM
CurtisShmigelsky1
Hello again with another newbie question
I have the point shp file as shown in the attachment, but I need it to a polygon shp file with each polygon having the area calculated. I was thinking of drawing the polygons in another layer and exporting that layer as a shp file.  Is that the proper approach to this or is there another way?  If so, how can you create a new empty layer and draw the polygons on it? ( I tried add data under the map tab but I am not seeing how to create a new empty layer and drawing the polygons on it)
Thanks again for the help
DarrenWiens2
MVP Honored Contributor
I know you're working Pro, but here's how you would find the unit in Desktop. I assume there's something similar in Pro.
