Creating MMPK to enterprise or local files fails
376
08-29-2025 12:47 PM
ScottHiggins_PVGIS
Hi all,
I am trying to package up as a MMPK some hosted layers. I have tried this layers, which originate from a postGres instance but are hosted reference layers.
...\Documents\ArcGIS\GN01_mobile.mmpk 27 MobileMapPackage 2025-08-29 15:30:16 Status: Failed ErrorMessage: An unexpected error has occurred when creating the package. Check your settings and try again.
Is the error in the log, which is generic, and is the same whether exporting the MMPK local or sharing it into Enterprise.
The settings in the Sharing> Map package are all good, and are the same as I have used in AGOL previously without issue.
Has anyone come across this previously?
Tags (4)
DavidPike
MVP Notable Contributor
Any issues I've ever had have been with the data being corrupted or incomplete in some way after an automated scheduled copy process.  The more obvious ones have been missing layers from the .mapx
I don't think there's any functional difference in sharing it into AGOL as it's just creating the MMPK in scratch/temp locally then sharing to AGOL (is my understanding).
Robert_LeClair
Esri Esteemed Contributor
This link describes one possibility for the error message as it relates to ArcGIS Pro licensing - Prepare maps for download—ArcGIS Field Maps | Documentation for ArcGIS Enterprise - what is your ArcGIS Pro licensed at?
Second item to share with you - Solved: License needed for creating Mobile Map Package (Sa... - Esri Community
