Creating a scale bar but for area, not length
962
08-08-2023 03:41 PM
BarrettLewis1
I have a map, on which I want to see a scale for acreage. Essentially I want the same thing that a scale bar does, but show area by units. This is obviously not possible with a scale bar, but how could I otherwise achieve this?
I was thinking of creating a polygon that perfectly fit the area I want to reference (100 acres). My idea was that somehow maybe I could get it to show up in the legend exactly as it is sized on the map at that reference scale, but I can't seem to do this either. How could I go about doing this?
WilliamSmith6
You could create a tessellation for 1 square block that represents acreage. Generate Tessellation (Data Management)—ArcGIS Pro | Documentation
Create Fishnet works in a similar way. Create Fishnet (Data Management)—ArcGIS Pro | Documentation
This may be a roundabout method, but you could then select and move the square or hexagon on your map. Or you could add it to a separate map and import it as a inset map with no basemap in your layout. That might look better.
