Create Database View
1348
08-30-2023 06:16 AM
ammsgis
Hey guys! I created that sql expression below in Create Database View to simplify the users queries and it worked well, but I've acrossed with some issues.
When I made join i lost the fields subtype_codes. Then, it remains just the associated default value.
Is there a way to conserve subtype_code after doing that join tables?
SELECT adhp.name_txt, adhp.type_code, adhp.military_code, adhpsurfacearea.subtypecode, adhpsurfacearea.globalid, adhpsurfacearea.length_val, surfacecharacteristic.composition_code FROM adhp JOIN adhpsurfacearea ON adhp.gfid = adhpsurfacearea.adhp_id JOIN surfacecharacteristic ON surfacecharacteristic.gfid = adhpsurfacearea.surfacecharacteristic_id;
In this case, the field is subtype_code from adhpsurfacearea.
Thanks in advance.
Tags (3)
DougGreen
It seems like you could join to the lookup table and display the values instead of the codes. It would follow this pattern:
SELECT
    adhp.name_txt,
    adhp.type_code,
    adhp.military_code,
    --adhpsurfacearea.subtypecode,
    LU.subtypevalue,
FROM
    adhp
JOIN [SUBTYPECODELOOKUPTABLENAME] LU ON LU.subtypecode = adhpsurfacearea.subtypecode
