Create a Locator and Apply Geocode Address to Brazil
1531
6
11-03-2021 09:50 AM
IaraNascimento
I configured the address finder to use data from Brazil and it is not working. I used the <As a defined in data> parameters and the locator and the geocode address does not work.
Does anyone have the Geocoder Address configuration pattern for the Brazil address pattern? It´s so important to me, I need to finish a work
How the locator will read my data out pattern of USA? We don´t have a direction street, like in the USA.
Iara
ABishop
Have you tried using the ArcGIS World Geocoding Service?  It uses credits, but could be an option?
Amanda Bishop, GISP
IaraNascimento
Amanda,
I am using an ArcGIS Pro. And I want to create a geocode to not use credits. I don't want to use an ArcGIS World Geocoding in this test. I am testing a Creator Locator tool.
ABishop
Understood.  Maybe there is a geolocation setting where you could change it from the US territory to Brazil?
Amanda Bishop, GISP
ABishop
Also, I found these tutorials online that may be of assistance in adding global locations to your locator.
https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/find-places-on-the-map.htm
https://pro.arcgis.com/en/pro-app/latest/tool-reference/geocoding/create-locator.htm
Amanda Bishop, GISP
IaraNascimento
Thanks, I managed to set up a create locator tool.
GustavoMartineli12
Olá @IaraNascimento,
Tenho o mesmo problema aqui, pode me dizer como resolveu ai ?
