Coverting polyline to CAD (Arcpro)
703
11-18-2022 07:07 AM
Iraj
when i convert polyline to CAD using arcpro, it appears as buffer when i open it in autocad software. see the image.
shows fine in arcgis or qgis but not in autocad.
Robert_LeClair
Esri Esteemed Contributor
I wonder if you use the Explode tool in the Modify Features pane to make single parts from the polyline, then run the Export to CAD GP tool on the exploded polyline feature class, does the DXF file in AutoCAD now show lines vs polygons?
