Copying valzes from DEM raster into polygon shapefile
631
09-05-2023 04:41 AM
TobiasWalter
I have the following problem: I converted a DEM raster for Germany into a polygon feature class using "Raster to polygon". I received a shapefile in which every polygon stands for a raster pixel. I would like to copy the values (altitude above and below zero) from the attribute table of the raster to the one of the polygon feature class. I use a join and it works, but the values taken over a wrong.
Can somebody help my?
Thank you in advance 😉
DavidPike
MVP Notable Contributor
Have you got an example of the issue?  A raster attribute table commonly is a count of the number of pixels which have that certain value, so I don't quite understand why you'd want to join that to your polygons as it doesn't make sense.
How did you create your polygons exactly?
