Copied a map from ArcGIS Pro to Online to ArcField but cannot now edit?
638
05-09-2022 01:51 AM
Sophia_Couch
I created a map in ArcGIS Pro.  This contained several point, line and polygon layers.  Data was then added to each of these layers.  I then published this map to the ArcGIS Online account.
My issue is that I cannot add the Layers from this published online ArcGIS Pro map to ArcGIS Field Maps.  Is it possible to add these Layers and then edit this data while out in the field.
CarlMorrison
Yes it is, but there are some settings for the Hosted Feature Layers that need to be set for it to work.  For instance, from your online content page, check your settings for the feature layers to make sure the "Enable editing", "Enable Sync" are checked on.  Check out this link for more in depth information.  checked your settings to make sure the hosted feature layer has "Enable editing", "Enable Sync" chec...
Sophia_Couch
Hi Carl, thanks for your reply.  I cannot upload the Layers into the Field Maps.  I think the issue may be the first step- moving the map from ArcGIS Pro to Online.
