Convert Count from GetCount to Int without using Pandas
2228
03-06-2024 10:29 AM
Ed_
by MVP Regular Contributor
Based on the code below how can I store the resultant value from GetCount in a numeric datatype? When I try the `int` function I  get the following error:
TypeError: int() argument must be a string, a bytes-like object or a number, not 'Result'
Code:
import arcpy
arcpy.env.workspace = "C:/data/data.gdb"
Count = arcpy.management.GetCount("roads")
Count = int(Count)
Question | Analyze | Visualize
Ed_
Never mind, the following fixes it by adding getOutput(0)
import arcpy
Count = int(arcpy.management.GetCount("roads").getOutput(0))
This post helped:
How to determine number of records using arcpy.da.SearchCursor
Ed_
import arcpy
This post helped:
MErikReedAugusta
Always proving there's more than one way to skin a cat[fish]:
count = int(arcpy.management.GetCount('feature')[0])
If you ask for the first index on that Result object, you get the actual result/number, itself—albeit as a string (I think).  Don't quote me on the exact datatype, but I know this is the syntax I typically use, and I haven't seen any errors from it, yet.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
