Is there any way to control the default behavior when adding .dwg files to ArcGIS Pro? The default behavior when I add the polylines from a .dwg is that Pro will create a separate layer for every layer in the .dwg. All I want is one singular layer that is the entire polylines, which Pro does create (and this was the default behavior in ArcMap) but then it also creates all the other layers as well. In other words I want a many to one relationship between the CAD and GIS layers, not a one to one. Cleaning this all up is time consuming as the CAD drawings I add typically have a large number of layers.
