Contents Pane docks on right side
144
7
Tuesday
Sheri_Wysong
Was working along  on a project, and suddenly the Contents Pane moved to right side and I cannot for the life of me figure out what I did to move it or how to move it back.  I can move it back to the left, but when I dock it, it goes back to the right.  HELP!
Sheri_Wysong
Thank you!  I kept seeing that arrow but couldn't figure out how to make it work!
Robert_LeClair
Esri Esteemed Contributor
On the Contents Pane, right-click just right of the word, Contents, and select Dock.  It "should" dock back to the left side.
Sheri_Wysong
Thanks, but it went back to the right.
Robert_LeClair
Well that's strange.  Whenever I see wonky behavior in ArcGIS Pro, I recommend a soft reset of ArcGIS Pro.  You can find the steps to perform this here - How To: Perform an ArcGIS pro Soft Reset
BSBlagojevic
Left click on pane and move on the left following arrow on screen put it on left.
Sheri_Wysong
Sheri_Wysong
Thank you for that info.  Luckily I did not have to do that, but I'll keep it mind if needed.
Sheri_Wysong
