Connecting to OneDrive in ArcGIS Pro
20622
11
09-21-2018 11:35 AM
HeatherScroggins
So in ArcMap (10.5.1) when connecting to a folder I have the option to choose my OneDrive folder.....
Since this is available in ArcMap I assumed that it was available in Pro, but when I looked I couldn't find anything. Am I missing something? Or is connecting to a OneDrive folder not available in Pro yet?
HeatherScroggins
So reading through that entire thread it looks like dragging and dropping the OneDrive folder in Windows Explorer into the Catalog pane of Pro is the way to get a folder connection to OneDrive.
Thanks for linking that article. I would never have thought to drag and drop a folder like that to make a connection.
George_Thompson
Esri Notable Contributor
I do not see my OneDrive folder either.
I would recommend reaching out to technical support to see if there is a request to have this available in Pro.
Here is another post regarding this: https://community.esri.com/message/770371-onedrive-arcpro  No solution just another idea
--- George T.
HeatherScroggins
MichaelVolz
Esteemed Contributor
I would also thank the person from the original article that discovered this trick.
Did you try to connect and save a One Drive data source in ArcMap and then import that mxd into Pro to see if the data source would be maintained in that process?
DanPatterson_Retired
The link picture is reproduced here, from my ...because I forget... collection
RandyKreuziger
What type of performance are you seeing between the local installs of ArcGIS and files on One Drive?
EllenNodwell_IntegraShare
Now with the newest version of ArcGIS Pro, the OneDrive folder link has disappeared.  Will be turning in a request for investigation to Support.
still works for me with the latest.  Drag from File Explorer and make sure you hit the 'Folders'
Hi Dan - Yes, once inside a project - in Catalog - this is true but in the initial interface when opening ArcGIS Pro, it is not - cannot drag the folder into that folder list view.
Am documenting this today to send over to support.
Thanks for your quick response!
Ellen West Nodwell, GISP
CEO
IntegraShare Dimensions, Inc
M +1 832 298 6892
