Combine themes of two layers
2331
12-28-2022 07:58 AM
LondonPoliceGISAnalyst
I have two layers that point to the same feature source.
Both layers have around 25 classifications coming from the same field (store_type)
I want to combine the two layer definitions so I end up with a single layer that has all 50 symbols.
Is there an way to automatically combine them?
Copy and paste the lyrx files?
thanks
For those who are interested, there is a great tool for just this issue:
"Apply Symbology from Layer"
This allows you to take all the symbology (symbols, line types, etc) and apply it to an existing layer.
I solved this by taking my layer with 26 symbols (Input Layer) and merged with the 24 symbols (Symbology Layer).
The result is that I now have all 50 symbols in my Layer all themed to the column I chose.
DanPatterson
MVP Esteemed Contributor
bring them into a map and
Merge (Data Management)—ArcGIS Pro | Documentation
then save the result to a new lyrx
... sort of retired...
The data is technically already 'merged'.  Its a single feature source.
Two separate Layers that point to that one single feature source (stores).
Each are themed 24 icons for one, 26 icons for the other. (field: store_type)
I need a single layer with 50 icons without the hassle of recreating all the icons based on store_type.
Basically I need a layer merge (lyrx), not a data merge.
CarlMorrison
Glad you found a method that worked, another option is to use the "Match Layer Symbology to a Style"  https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/match-layer-symbology-to-a-s...
