Color Separation in ArcGIS pro
1386
09-27-2020 03:01 AM
ahmedmohsen
Working with ArcGIS pro and Spot colors
Am trying to export several PDF files for each spot color used in my Layout
Our system is using 7 spot colors which is then separated into several mxds each contains a single color and exported to be sent to printing , this separation process is an old VB code done on 9.3
So my question is ?  is this process of separation is available on arcGIS Pro or not ? and if its not available what is the best way of doing a custom code to automate the process using spot colors ?
DanPatterson
MVP Esteemed Contributor
searching for "spot colors" (with quotes) in the help yields
Define and use spot colors—ArcGIS Pro | Documentation
Color—ArcGIS Pro | Documentation
Text formatting tags—ArcGIS Pro | Documentation
apparently introduced in Pro 2.5  What's new in ArcGIS Pro 2.5—ArcGIS Pro | Documentation
Is this what you are referring to?
... sort of retired...
ahmedmohsen
I have seen all of the documents which describes how to define and allow working with spot color in arcGIS Pro projects, but what am looking for is how to share this layout as a separate colors pdfs each contain a single color
something similar to Production PDF in ArcMap , check this out
https://desktop.arcgis.com/en/arcmap/latest/extensions/production-mapping/configuring-separation-set...
