Color ramp stretch in ArcGIS Pro 3.4 not exporting accurate/chosen colors/enhancements (png, jpg, pdf...)
920
03-10-2025 11:38 AM
a_bayard
I want to export a map with the GEBCO raster bathymetry stretch/ other settings to look like the image on the left in the PNG attached, but it keeps exporting using the default stretch on the right in the PNG attached.
I see that there are some references to "bugs" with people seeming to have similar problems, but I can't find a solution to my issue.
I tried png, jpg, pdf, and svg and they all come out like the version on the right... I also enabled color management, saving as a layer file. When I close and reopen the project, it defaults to saturated  version on the right as well. I also tried: changing the png settings...and a few other things...
Any help/ideas would be much appreciated!
a_bayard
Update (in case any ESRI folks are lurking): Someone was kind enough to try to replicate my issue and found the same results when trying to export a map with slight color enhancements as well. I also tried using the ESRI ASCII (vs GeoTIFF) version and had the same results, but had success exporting changes in QGIS. I'd prefer not to have to remake maps in QGIS at this point if possible and didn't want to use the ASCII versions anyway since they are more than double the file size...
