Clip Tool Not Working in ArcGIS Pro
389
11-26-2025 12:32 PM
ziadeid
**I’m using ArcGIS Pro (version 3.x) and I’m having an issue with the Clip tool.
When I run the tool, it doesn’t produce any output. The process finishes instantly without creating a clipped layer.
I tried the following but the problem is still happening:
1. Using different input layers
2. Changing the clip feature
3. Restarting ArcGIS Pro
4. Checking the projections of both layers
Here are the screenshots.
What could be causing the Clip tool to fail, and how can I fix it?**
CodyPatterson
MVP Regular Contributor
Hey @ziadeid
The pictures didn't end up coming over, imgur or paste on a comment may work!
Does this solution in this post here help?
https://community.esri.com/t5/arcgis-pro-questions/modify-divide-clip-doesn-t-work/m-p/1218889#M6069...
Cody
ShaneONeill_144
Could you confirm the exact version of ArcGIS Pro that you are using? Additionally, could you provide us with your screenshots again? They haven't been included in your original post.
