clip raster tool freezes/ gets stuck on saving raster
1106
09-05-2023 12:05 PM
AaronSundquist
I have about a 3700 acre drone mapping project (standard rgb) that i am working on. I completed the project in 9 different datasets. I merged them together into one mosaic dataset and now need to trim off the excess so it only shows the true property boundaries. When I attempt to use the clip raster tool it will let it run but gets stuck on "saving dataset..." Ive tried it a handful of different ways now to see if i could find a work around. Thinking it could be something simple but pretty stumped on this one. TIA for help.
DanPatterson
MVP Esteemed Contributor
This worked in a similar situation
Solved: Clip Raster with Polygon Freezes ArcGIS. - Esri Community
Your destination raster type and saving location may provide alternate suggestions
... sort of retired...
bcdi
New Contributor II
Dan can you elaborate on what it means for a saving location to provide alternative suggestions?
DanPatterson
If your saving location is a folder, then you can specify a raster as a *.tif if you use the extension on the filename, or if you don't, you get an esri grid.  If you specify a geodatabase as the location, then you get a geodatabase raster.  All have different limitations and potential issues.
