Clip_management fails to Esri Land Cover map
407
10-04-2025 04:19 AM
ThomasMiller24
I'm trying to clip a small section of ESRI Land Cover layer using a python script I'm developing, but I keep encountering a Error 99999 message. I have reduced the extent to the required size and that still doesn't work. It works fine when I run it from the Geoprocessing tools. Code snippet is below and I'm using ArcGIS Pro 3.5.3. Someone suggested REST services don't work in Pro but I've tried the non-REST link also and still no good. Any ideas where I might be going wrong? Thank you!!
Tom
transformed_extents = '-420353.6209754332 6857701.481562025 -394409.69783226284 6881148.42889701'
'PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],' \
'PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],' \
'PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]]'
temp_output_raster1 = os.path.join(ScratchFolder, "step_2_8_temp_raster1.tif")
with arcpy.EnvManager(extent=transformed_extent):
            arcpy.Clip_management(input_rastertransformed_extentstemp_output_raster1maintain_clipping_extent="MAINTAIN_EXTENT")
DanPatterson
@ThomasMiller24
transformed_extents =    # -- ends in s
with arcpy.EnvManager(extent=transformed_extent)  # -- no s
arcpy.Clip_management(input_raster, transformed_extents  # -- ends in s
it may have failed with the 99999 error because of the with statement
... sort of retired...
ThomasMiller24
Thanks for replying - good spot on the typo.
Unfortunately, I wish it were that simple 😭 I think the above was because this editor converted the 😞 to a sad face and in editing it, I deleted the s by mistake.
That being said, I spotted another type:
arcpy.Clip_management(input_rastertransformed_extents_strtemp_output_raster1maintain_clipping_extent="MAINTAIN_EXTENT")
where transformed_extents_str = '-420353.6209754332 6857701.481562025 -394409.69783226284 6881148.42889701'
Sorry for any confusion
Either way, I'm still seeing the same error message
DanPatterson
assuming the output coordinate system matches the input and the extents are correct, the only thing I could suggest for a try would be to hardcode the output path and use a different output filename in case overwriteOutputs isn't set to True.   Dump the 'with' portion as well.
If it works through the tool within Pro then your script will have to match the Environment settings for the script to work.
Good luck
ThomasMiller24
FYI it's working now. Not entirely sure why but it seems that the connection to the REST server can be a bit unstable.
