Is anyone aware of any useful functions using arcpy.mp that would allow me to select one particular layer in my table of contents and then change the data source of to another file path?
You can do it with updateConnectionProperties() method on aprx object for all layers in a project or layer by layer if datasources are differents :
See example here : https://pro.arcgis.com/fr/pro-app/latest/arcpy/mapping/updatingandfixingdatasources.htm
Thank you for sending me this page with information to updateConnectionProperties(). I did not see any code in here that could change the data source of just one layer in my aprx. For my script I would want to change the data source for just my AOI that could potentially come from a Shapefile that comes from an external source. Can you specify how that might be done?
You can try something like this in the console python of your ArcGIS Pro project (or in jupyter notebook window):
import arcpy aprx=arcpy.mp.ArcGISProject("CURRENT") map = aprx.listMaps("Map Name with layer")[0] layer = map.listLayers("Layer Name to change datasource")[0] #Connection properties are like this for shapefile #{'dataset': 'xyz.shp', 'workspace_factory': 'Shape File', 'connection_info': {'database': '[FILE PATH HERE]'}} cp = layer.connectionProperties cp['connection_info']['database'] = [NEW FILEPATH] cp['dataset'] = '[NEW SHAPEFILE NAME].shp' layer.updateConnectionProperties(l.connectionProperties, cp) aprx.save()
You have this method in the part 4 of section "Using the connectionProperties dictionary" : https://pro.arcgis.com/fr/pro-app/latest/arcpy/mapping/updatingandfixingdatasources.htm#ESRI_SECTION1_1ACA0FBD09924B56A43CE5A5DBD18D7D
