Centroid of polygon stored in a Geographic Coordinate System
428
04-24-2025 01:37 PM
DavidPike
MVP Notable Contributor
Following on from this thread Re: Creating multiple non-overlapping buffers - Esri Community
I've noticed that Centroid calculations for GCS features seem to be calculate as if the lat/lon coords were transcribed onto a cartesian plane i.e. Plate Carree and the Centroid calculated from that.
It all seems a bit off to me.  Am I missing something obvious?
DanPatterson
MVP Esteemed Contributor
centroids are related to area as you probably already know (sometimes called center of mass)
There is no agreed upon method to calculate centroids, but a first step would be to use a projected coordinate system (area preserving is desired).  If you aren't working on a country, or other large area basis, I would use projected data unless you have another reason not to.
... sort of retired...
