Catalog of ArcGIS Pro doesn’t show the coordinate system of the feature class,
2847
14
11-17-2017 03:43 AM
JamalNUMAN
Legendary Contributor
Considering the fact that the Catalog of ArcGIS Pro doesn’t show the coordinate system of the feature class, does this mean that we need to add the feature class to a map in order to recognize its coordinate system?
Jamal Numan
SimonKettle
Robert_LeClair
Esri Notable Contributor
You could right click on the feature class in the Catalog Pane and select "View Metadata"  Inside the Metadata, go to the Spatial Reference section and there you will see it without adding it to a new Map View.
JamalNUMAN
Thanks Robert.
Not sure but I found nothing related to spatial reference in the metadata as shown in the screenshot below
Jamal Numan
DanPatterson_Retired
you have to scroll a bit
JamalNUMAN
Thanks Dan,
My issue here is how to recognize the coordinate system of a feature class from the Catalog Pane but not while we are working in the Content Pane.
Correct, the Content pane does show the coordinate system but this means that I need to add the feature class to Map just to check its coordinate system
Jamal Numan
You have a weak metadata setup
go to the Options pane and set one, so when you explore 'Metadata' in catalog all will be revealed.
XanderBakker
Esri Esteemed Contributor
If you want to explore the coordinate systems of the layer in your map you should use the Map properties windo, select "Coordinate Systems" and expand "Layers" to see what coordinate systems are in use by which layers.
(just like you are probably used to do with the data frame properties window in ArcMap)
JamalNUMAN
It appears that there is no simple way to approach to recognize the coordinate system of a particular layer straightaway from the Catalog in Pro as it is available in ArcMap (all can be found by right clicking the layer)
Jamal Numan
Choose the FGDC metadata option... your option selection is not very good, nor is having a file with an unknown coordinate system
JamalNUMAN
Not sure why should I experience all of this just to recognize the coordinate system of a feature class. I think this should be made straightforward as in ArcMap
Jamal Numan
