Cannot add more than 1 grib file to a mosaic at a time
424
07-01-2024 07:47 AM
JasonJordan00
Trying to create a multidimensional mosaic dataset using GRIB files from NOAA. My tools were working fine in Pro 3.1 but not in 3.2. When I go to Add Rasters to Mosaic Dataset, I'll the the configuration for GRIB and point it to a folder. It just returns
2024-07-01T09:34:55.049: Loading raster datasets
2024-07-01T09:37:55.418: Completed crawling 0 data source items. Added 0 mosaic dataset items.
2024-07-01T09:37:55.421: Error: 8004818c: No new mosaic dataset item was added.
I tried just adding the files paths in as datasets and got the same result. When I load only a single file in it gets loaded to the mosaic just fine. However as soon as I load a second file in it fails. The files are all the same area, variables, and resolution. Any ideas?
